Sell it to me for parts martin. Lol.My rubber flange on the bearing housing unit is no good. Polaris no longer sells the bearing house. Couldn't I just make a thin rubber gasket and bolt it back on to stop it from leaking ? Makes sense to me. I am not a jet ski mechanic. Any advice ?
Usually.My Octane has four bolt holes in a square pattern in side the compartment hole. I saw the five bolt pattern on the house bearing. Only took out four bolts to take out the housing bearing. The three on the bottom on the octane housing I am not using the middle bolt. I think Yamaha has three bolts two on top and one in the bottom middle. Makes a triangle pattern ? I am I wrong ?
If you want to sell your bearing housing to the octane I will buy it.That bearing is just to keep the shaft from moving without the seal going with it. That unit just keeps the water out of the engine compartment. You would be better off cleaning the rubber very well and filling it with some sort of flexible stuff. I've got a mint condition housing but I'm not sure I want to get rid of it. Octane is the 5 bolt pattern. Fits yamaha 3 bolt also. 3 on the bottom and 2 on top
All I can get plus some on top of that. How much are they newHow much do you want ?
Its 170$ for a new one with nothing in it. Its 250 with bearings and seals. And that thing from the couch ain't even close lolYamaha superjet midshaft our house bearing goes for 160. They don't make the polaris part so I don't know what they would sell for. I now your going to get a lot more .
The Buzzard do you still have a running octane for sale ? I read some of your other post from 2018. I hear you had two ?
