- prescott arizona
Glad to hear this ! your prototype nozzle was a touched on topic of discussion at this weekend ride sesh .Are you still able to run a trim system with this "big ol" nozzle ?
So you can see how good it works...View attachment 276274
10/16 impeller in a Oem 155 95 mm nozzle and what power plant?
Awesome work though!!
did you taper bore it or straight ?Had my nozzle bored to 89.5 and deffo made some difference, would like to try go larger. Have a spare nozzle so will try glassing that, or is there any i could buy that are larger?
Thanks.
It's actually very close in price , once you factor in 155 prop, reduction nozzle, 155 seal and pump shoe
Im scared to say anything. As people way more educated than me will tell you differently. I run 155 and wont go back. Tunnel needs to mate. Mate.
@DAG if your intake tunnel can feed the 155mm pump, there is a big gain to get, getting a OEM 155mm pump over a 144mag and 148mag pump.
How do you know if your intake tunnel is big enough? I have a stock 95 701 I want to do the 155 conversion with b2 pump and gp1200 trim ring
I used a gp1200r style nozzle and welded on mounting tabs. The nozzle has interchangeable rings. I can change both steering and reduction nozzle dia. I was running a 7/14 with good results on the standard cone and no spacers. If I went to a stubby cone I could reduce that diameter. Like I said 86mm reduction and 90mm steering icouldnt even get the ski to plain on the water. Pump tuning is very important in my mind and takes themost time to find a good combo.
