aqua
the taco
- Jefferson City, MO
I just bought a set of dual oem 44's with stock f/a and stock intake manifold. when looking at them i noticed a couple of things.
first, the carbs mount backwards compared to my 38's....even the throttle cable attachment is now on the rear of the carbs vs. the front of the carbs where it is on my 38's. the throttle/choke cable mounting plate mounts on the back on the manifold too.
second, they have primer fittings built in to the f/a mount and they have choke plates that I was thinking about removing.
how are you guys mounting these things and still having access to the adjustment screws. i would like to turn them around so that they are facing the same way that my 38's mount but if I do then my bolt holes in the intake manifold that hold the throttle cable mounting plate will be on the wrong side. how is everyone mounting these.
also i am wanting to take out the choke plates and will need to plug in the choke shaft holes. i guess i could jb weld that too unless someone has brass plugs that i can plop right in. thanks yall. :biggthumpup:
