227
Its all about the surf!
- Oceanside, CA
I think if I lived on the surf I would have an AM hull sooner.
Dont you want the increased strength/width of an AM hull?
Well maybe if your plan was to move somewhere which typically has small surf, but if your thinking larger surf then what advantage are you thinking you will gain buy going AM? As far as strength every AM Hull I've seen are light and flimsy and still need reinforcing if ridden in larger surf, and those wide short hulls handle terrible in the surf. For rec riding, you can't really beat a reinforced OEM SJ with a set of Tubbies in decent size surf. I'm not hating on AM Hulls, they definitely have their place, It's just that when you weigh out their cost verses what they contribute your definitely in the red as far as diminishing returns
