no hull reinforcement needed! just nose reinforcement. IT WILL COST U AROUND $1500 FOR ALL THE FIBERGLASS MATERIALS, SUPPLIES, AND RESIN. its expensive, im in it too deep to give up now, but if i knew about what i was in for at the start, woulda bought a decent mid 90s 750sx or superjet lol, and just kept this 550 a usual 750 conversion. BUT theres a flip side, nobody else has this hull cause u built it, you get the lightness of the 550 hull (even with all the glass and filling my hull and hood arenot yet over 90lbs, which is very good because a carbon/ kevlar 800sxr hull weighs 105lbs, so im doin good on weight), and it will handle as good as the 800 SXRs in the turns from the tubbies and the strake mod, and will be more stable, and with the 650 pump cavity, i can run a nice 650 or 750 pump in it (they are pretty much the same thing), and the rocker nose helps get the ski i the air quickly. so go the route u choose, but let me tell ya, its a HELLA lot of work! and u could buy an average mid 90s superjet for what u will spend. but hey, IMO !!! this thing will own a superjet when im done.. any year superjet, as long as its not built like this, then i should be able t whip any superjet with this. superjets at least the ones ive owned, mid 90s to late 90s, theydont have a fast top speed, i think its cause i never pulled the rev limiter from em, but they had the best bottom end hit, better than an 750 sxi pro with a factory pipe (yes i had both and raced em, 750 won in the longshot, but my stock 91 superjet had it at the line, no doubt about it)
