Mouthfulloflake
ISJWTA member #2
- NW Arkansas
so, since one of my boats is stripped, I was thinking about adding the Home Depot style one way valve.
ive already got the foot holds installed, so can I cut the tray in front of it and install like that?
or is it possible to use a pvc tube the same size as the one way valve, and then do it all from the back end?
whats the smallest diameter hole the one way valve will fit thru?
part of my thinking is that if it ever needs replaced or serviced, I would rather be able to pull the whole assembly out thru the back instead of cutting the tray open again.
