Lucifer
Jet Junkie
- Croydon PA
Hi all. I'm building a squarenose for freeriding. What do you think about having a tilt mod? Is it really needed for the surf?
Thanks, Lucifer
Thanks, Lucifer
I have the nozzle trimed up just a little and have found it keeps the nose from pearling as easy on a wave.
For freeride a trim system is not necessary, You can always add it later if you feel you need it, but have never used one in the surf.
I recently switched to an 09 SJ nozzle which has a trim ring on it. I have the nozzle trimed up just a little and have found it keeps the nose from pearling as easy on a wave. For flips in the surf you do not need it though.
Thanksgood idea eddie.
how does it affect the ride when you are just cruising around?
does it want to ride real nose high, or not so noticeable..?
they actually help with setup wakes.
you pull the trim as you make the setup wake, makes the wake bigger.
(Flatwater)
Your problem is clear, you are ridding the wrong ski. :spank:I loved my trim i had on my sj! have a freeride sxr now without a trim with a sxr nose you submarine a lot in the surf coming back from waves, .
