Phantom Resurrection
Picked this up the end of last year. I wanted to get some practice turfing footholds. Classic ridden hard put away wet needing some TLC.
The punch in from the tray or, where the ebox mounts was thin so I beefed it up with a single layer of 1708 overlayed with 4oz. Wound up doing the sides when they couldn't pass the candle test.
There was a chine crack right in front of the bulkhead. I ground it back and used 7 layers of 1708 ,and lots of pressure for the patch.
I was using compressed air to blow out the motor mount holes and I thought I was hallucinating but the mount on the right was popping up and down about a 1/4 of an inch. So I made a locator from the good mount, and used a dremel to cut the carbon.
Ground off all the carbon, hogged out the bottom of the mount with a 4 inch grinder and bonded back in place with 404 and epoxy. 2 layers of 5.7 carbon were layed over the mount like originally done.
This is what I did for new inserts. I decided to use M10 Rotolocs, yes big manly M10's, if I need a smaller bolt EZ Lock makes a M10 to M6 adapter. I used dished washers to make covers for the epoxy and to press in place. I made placement studs out of 3/8 bolts, M10 and 3/8 are just about identical thread.
I wanted the tray to be removable so I used a blister pack from some 60amp fuses to make a mold. Food wrap and a rag, popped these out.
