- 1 Mile High in Colorado
The fun begins...
About to pull er outta there
Engine bay is pretty clean
When tearing stuff down that I don't intend on scrapping I've learned to keep track of all the bolts in my older years...
Kept track of the engine shimz and their orientation in the engine bay (FR, FL, RR, RL) Interestingly the rear left had the thiccest shimz.
After getting the engine out of the bay I gave the midshaft a spin... doesn't really feel too solid - feels like some radial play - is the midshaft suppose to feel very tight in tolerance or does it have some slop? First time playing with a superjet setup.
But after that I started tearing the engine down to the core.
Pretty fresh water-ish lookin! Previous owner said they acquired it from their friend that owned it in Wyoming so still not much beach front there.
Ebox lookin pretty fresh as well
And stator lookin fresh from what I can tell... This ski is pretty damn fresh all around - if someone has a link to the ohm values for each coil I can check that for a go/no-go.
And finally - 20 year old stainless reeds. Very Sano. Much Fresh.
Got a few tools coming to start the next stages - I guess I should probably get a re-manufactured mid-shaft for ease of mind since I'm in this far. Is it worth looking into billet couplers or are they just unnecessary bling with a mild build like I'm doing? The stock coupler rubber damper is also lookin pretty fresh but is that considered a standard wear item that should be replaced in this scenario? I figure while it's apart - it's a good time to replace stuff.
But I ain't touchin no fiberglass - no dewey cox you don't want that...
