Yeah I could never understand that eitherIm sorry but when someone mentions freeze plugs it makes me cringe. Theres no such thing as freeze plugs even if autozone sells them under that listing for your 350 small block. They are casting plugs. Sorry again! Im out before the beatings start!
i think its from one of the OEM cuplers u might need a washer and a new cupler.
Is that what you told her?Must have been ready to go when l put it in.
I'm with Toby.... believe you forgot a coupler washer.
Thank you! I'm not alone!
do i see cracked windshield when the nice and hot juice hits it?Your not alone, your just from the south.You are probably equally confused by the concepts of block heaters, cab heaters and battery blankets, lol.
These just hit the market around the time I moved South of the border;
http://www.windshieldwiperheaters.com/
Its the center of the coupler. The coupler bottoms out on the washer but without the washer the midshaft bottoms out inside the coupler and as its screwed tighter it pops out the center. If ur driveshaft orings leak i would think water can get in ur hull.
