- Glenmoore pa
What have people used to plug a hole where a pisser used to be that doesn’t look like crap? I need to relocate a pisser but don’t want to just slap a stainless bolt in there. Ideas? Thanks!
Cut it and fill it with silicone. *shrug*I guess I could cut the back off and weld it up but it would probably destroy the anodizing.
This is usually what I do, then I eventually fill the back in with resin.Or just cover it with a sticker and be done.
That’s a decent idea. I’m kinda leaning towards a bolt of some type that looks like it’s on purpose. I’ll experiment. Thanks for all the ideas!How much room inside do you have? Could you use a countersunk washer and bolt like rickter footholds use?
I like that idea!!! Man, who knew this thread would get so many responsesI have used (M8) stainless carriage bolts very successfully in the past. Countered with a big washer and a nut from the inside. If you want you can paint them to match your hull color or what ever. A bit of sealant and your good to go in minutes...View attachment 386532
I have used (M8) stainless carriage bolts very successfully in the past. Countered with a big washer and a nut from the inside. If you want you can paint them to match your hull color or what ever. A bit of sealant and your good to go in minutes...View attachment 386532[/
QUOTE]
IMHO-over thinking
Y’all have taken something so simple and complicated it.You could have already fixed it and been done as long as this thread has gone on
Have a nice day.....
It’s always the simplest questions to answer that get the most responses cause everyone knows how to answer them.I like that idea!!! Man, who knew this thread would get so many responses
