Does your lock work w the hazard bracket ?Our original RCJS Pole bracket in stock here. Works with your stock SN pole bolt;
Handle Pole Conversion Bracket
This is our Original, WATCON handle pole mount conversion bracket. It allows you to run a 1996- later Round Nose Super Jet pole, stock or aftermarket on an earlier 1990-1995 Square nose SJ. Ours uses the SN pole bolt, no need to purchase anything extra hardware. Accept NO copy's! Part...watcon.com
But will it work with a KP pole?Our original RCJS Pole bracket in stock here. Works with your stock SN pole bolt;
My mistake , I thought this was something that bolted onto the bracket ?Our bracket is not a "hazzard" bracket. That is a member here....
With a RN pole, the stock pole lock does not work, if that is your question.
