Yami-Rider
TigerCraft FV-PRO
- Texoma
Our JM 781's ran great with OEM 38s. I'd stay dual 38 till you go over 800cc.
I'm trying to convince Prosouth to save money on aftermarket carb and single intake and just get OEM 38's. I don't think it's worth the money to go to a single.
if every carb setup you have on your list is perfectly tunes for that motor, no single carb setup is going to perform as well as the dual setup. the bigger the duals, the higher the motor will rev. the bigger the carbs, the more throttle response/bottom hit you lose. stock dual 38s were designed for a stock 701. I would go with stock dual 44s off a 760 motor. use the stock carbs, intake and reeds. its a dirt cheap setup that I have seen increase power over single novi 48 setups and dual 38 setups
Dual oem 46's. I believe @waxhead and groupk talked about how the 46's are significantly better (signal responce and flow) then the sbn 44s.
I think you mean oem as in not Buckshot or Novi or some such? It can be confusing because some people distinguish between the 44's that came on the yamaha 760 as "oem" where 44's that you buy from mikuni that didn't come stock on any machine are different and somewhat more desirable. So "oem" can mean unmodified from Mikuni but never came on a ski, or "oem" could mean it came as oem equipment on a ski.
And every setup while may be almost the same will be differentEvery one is entitled to their opinion based on their own testing. Lot of different thoughts is what makes the world go round
