@Pro-pulsion you are correct, the carbs themselves need to be identical.
Like Erik stated, start by drilling out your returns and install a restrictor jet with a #70 in it. only use auth Mikuni parts!
the idea of using a "T" to tie the carbs together with a single restrictor is to equalize the pressures within both carbs
Make sure you have matching needle /Seats, springs? once installed, do an actual pop off ck to verify they are the same?
slight bending of float arm is acceptable to get the pop-off identical.
The Mikuni SBN manual is a very good resource for people just learning to tune for the first time.
It can be downloaded for free here
http://www.mikuni.com/pdf/sbn_manual.pdf
@long beach local The Powerbomb carb once tuned is a nice carb. Most people tuning one for the first time,
might find it somewhat difficult to understand?? they normally like lower pop-off as the signal off it is weak compared to some other carbs?
When you had your cases ported, you increased the case volume, and slowed airspeed thru the case. both the arrestors and V3 further tend to restrict flow??
I agree with Erik to raise your pop-off your current pop will be about 17#?? change out your N/S to a 2.3 with a 95G spr to be at about a 20# pop
try this first with just needle adjustments? You might need to go to a 130 pilot? ( raising pop-off makes the pilot jet act like its smaller) You can also experiment with drilling out the return, and tapping the return fitting for a Mikuni main jet? start with a #70 return? you might find yourself going as low as a #55?? I agree, put the 140 main back in? overall, your probably not going to need more fuel, but rather when you need the fuel delivered?
This thread went full circle, but I like where its headed now! lets stay positive! One thing I feel we all learned is the amount of Bad info being circulated??
If you only have marginal experience? That's fine, we all have to have the opportunity to learn. Just don't come off as gospel when you try and give advise?
Ski Ya, Paul
