waxhead
wannabe backflipper
- gold coast
What compression do you have in the engine
I have a 61x cylinder I had bored to 84mm and ported it myself using the port templates sold on here. I had a head shaved and cut for the 84mm bore and big race gas compression. In my old square nose, I put this on the stock 61x cases and carb, with a protec black pipe. This combo was very linear and great to ride.
Then I got a deal on a RN I couldn't pass us. I kept my cylinder and head from the square [just swapped them between skis and sold the SN] and put it on the RN. The differences are the RN has oem 760 dual 44's, and a limited chamber B pipe. It now rides exactly like your 91. Anything below half throttle, it is linear and adjustable. Right around half throttle, it explodes like a cannon and more throttle doesn't feel like it does much extra. Pretty sure 5/8ths throttle is about as fast as 8/8ths lol. Yes, its much faster now. But I really hate this light switch response. I want to be able to cruise at half throttle and get half throttle power.
lol my point was to show the OP that porting does not influence the powerband like he was asking, as the same ported cylinder and head react very differently when different parts are bolted on.With big carbs you get to the point where the diffeence in throttle plate angle makes no difference as the engine has all it can deal with. This is why it seems you can give it more and it just gets louder not faster
So why big carbs. Because they give you mid range torque.
How is the water on your n-pipe set
What are the jets on the 44s. so much to be sorted before you determine why its doing this.
How strong are your arms, Most people love the hit ?
Ahh but using someone elses jetting specs for the same setup is a great starting basis. Especially when it starts great, idles great, and has excellent power. The rest is a matter of dialing in the combo [i hope]Reverse jetting works great if you like to fan the throttle all the time as most riders do. If you are smooth on the throttle it will likely be horribly rich under the pipes operating range, 1/4-1/2 open throttle. Smooth throttle guys are much better off if they power tune the top screw rich of peak rpm then make the pilot just rich enough for good response. Using someone elses jetting specs is foolish at best.
