porting question
i got 2 61x cylinders ones a 80mm and the other is a 84mm big bore and they both were ported for a superstock race boat, would it be a bad idea to put the 84mm that's heavily ported and epoxied in a freestyle boat?
Waternut
Customizing addict
Macon, GA
Without really knowing how it was ported specifically, I think it will be hard to say. However, since it was originally a 61x, I doubt it would be any worse than running the 62T big bore.
Kennay
Squarenose for the _____
Myrtle Beach, SC
Crammit's super stock is a freakin stock stroke animal, so I vote yes. Don't listen to some of the cotton headed ninny muggins on here that tell you it won't work. Set up with the right combo of parts, it's probably better than most of the freestyle engines here.
hmm yeah i was just told the porting was made for racing and will no work.. but no matter what i need to bore either one of tease should i just bore the hevily ported and epoexed 84mm and use it or bore the lightly ported 80mm
Post pics of the porting. Also measure from the top of the cylinder down to the top of the exhaust port (in millimeter's please).
Has the 84mm cylinder been resleeved for big bore, or is it a 61X stock sleeved to 84mm?
Aaron
pics
Waternut
Customizing addict
Macon, GA
Can't really see anything in those pics...the thumbnail is as big as I can get them.
I just found this thread that might prove useful. http://www.x-h2o.com/threads/21863 If you scroll down, there are some big bore sleeves that show distances from the top of the exhaust to the top of the cylinder. #.0 says that the 62T sleeve is similar to the LA YA-5187B. If that's true and a stock 62T sleeve is around 37-38mm from the top of the cylinder, 34.5mm from the top is probably going to produce some wickedly bad bottom end performance. Also if you scroll down to post #36, 1550 posted a mapped cylinder that he bought off ebay. If your's is similar to that, I'd take #.0's advice.
man i read it all from what it sounds like mine is not going to work. thanks for the info but now im going to go measure my 80mm cylinder and see if i can get something out of that one
im just trying to see if i can use this other ported cylinder for a freestyle boat cause it was in a race boat
