Post your AquaBot PICS
StandupWI
Sinking with the bilge on
Milwaukee, WI
Received my Bot yesterday, pumped to start the build!
Vegas
As it sits right now. All that I need is my handle bars and bpipe to waterbox coupler run fuel and waterline and she's done!!!
Oh and my wrap from Racu designs :)
Vegas
I haven't actually bolted it in yet I'll be doing it this week and get back to you.. right now I'm waiting on a bpipe elbow cause I had the wrong one
What's the black circle on the starboard side of the dash? Any pics of hood breather system? Good spot for the pole cushion, clean and out of the way. Does it provide enough resistance in that location with the leverage available so near the pivot point to protect your hood from pole slamming down? Or, is that not its intended use?
If I had a choice, regardless of hull, to run a stock or a Limited Slip tank it would be the latter hands down. Nice thing about the Bot is that you can have discussions about what 5 gal tank you're gonna run in it. Not a lot of AM hulls that you are able to do that.
Stock will fit just fine, although the limited slip tank is a great alternative.
Who makes that tank and do they powder coat as well ... also... how much... ???
My stock tank fits without any problems... centered up in BOT... level and yes snug.... but... it fits... stock battery box hits front motor mount and it will prob work if I shaped it and put spacers underneath... but... I am not a hack so I would prefer to buy another battery box that fits... I was told a Rad Dudes box fits fine... if Cold Fusion fits... that is what I will go with... !!!
Vegas
That's. Not my pole cushion that's my chin pad that's just sitting there loosely. My pole shock pad is glued centered on my hood.
That's a cold fusion tank that went in easier than a stock tank on a superjet.
964Chris
FREEdumb obtained
TEXAS
look for limitedslip7 here on the forum. He makes them. Can't beat the quality of these tanks. Good guy to deal with.
KTM434
Jamie FN Hickey
Palm Coast FL
Stock SJ tank goes in and out easily with engine installed. I've done it many times with beefy TPE cylinder and thicker billet flywheel cover as well as stock 701 with girdled ADA head. It's tight but very doable. Rad Dudes battery tray fits as well as many others I'm sure
Vegas
Finished my build today super stoked it went together fairly easily, cold fusion battery box worked perfect .
I'm super stoked that you can install the Bpipe on the the head pipe outside of the ski and there's room to slide it in the ski as one piece, super easy and Im stoked about it cause I usually struggle with it with my big fat hands on my old sj, the build was super easy and went together well once I got the right parts for each application
