StandupWI
Sinking with the bilge on
- Milwaukee, WI
Received my Bot yesterday, pumped to start the build!
Looks good... what battery box did you use... ???As it sits right now. All that I need is my handle bars and bpipe to waterbox coupler run fuel and waterline and she's done!!!
Oh and my wrap from Racu designs![]()
It fits no problems with the tank and motor mount... ???Coldfusion
What's the black circle on the starboard side of the dash? Any pics of hood breather system? Good spot for the pole cushion, clean and out of the way. Does it provide enough resistance in that location with the leverage available so near the pivot point to protect your hood from pole slamming down? Or, is that not its intended use?As it sits right now. All that I need is my handle bars and bpipe to waterbox coupler run fuel and waterline and she's done!!!
Yes it does tight fight like a rn on my v1 anyways has to b put in before motorStock tank fits in the bot also?
Who makes that tank and do they powder coat as well ... also... how much... ???Stock will fit just fine, although the limited slip tank is a great alternative.
My stock tank fits without any problems... centered up in BOT... level and yes snug.... but... it fits... stock battery box hits front motor mount and it will prob work if I shaped it and put spacers underneath... but... I am not a hack so I would prefer to buy another battery box that fits... I was told a Rad Dudes box fits fine... if Cold Fusion fits... that is what I will go with... !!!
