Look at a oem stk setup-IT'S A FREEGIN BUCKET TO SCOOP WATER RIGHT INTO THE CARB THROAT.
not if youre not under water and upside-down. simply learn to ride. :dunno:
I have used proks,tau cetis,old style flat metal forgot name and OEM's
For us the problem is horrible thus we are at high altitude so if we open up with aftermarkets to get more air we get more water, the outawears hold the water too long, so I decided to use OEM's and remove one/two layers of mesh and the results are great !!
But I am lacking Risers for a "reasonable price"
After seeing all the sand in the bildges of the ski's at surf slam it made me wonder if that was what outerwear's were designed for. On day 2 Matt_E lost his motor but he also sank his ski 3 times the first day and I was thinking sand ingestion was the problem. Evidentley it was a crank bearing failure that was not caused by sand IDK! We don't have sand here to speak of on the lake or the ocean. I really never gave it a thought for them keeping out the sand before this.
Yep :spankme:Clueless.........lol
Maybe it's just the rubber seal leaking?Chuck told me that if an outerwear was needed get a new hood
I have tried every combo possible...
Nothing beats a stock air box setup period.
-Andrew
why not use a stocker?
I lost around 250 rpm with these pre-filters installed but they do keep the sand out.
I run the marine K&N FAs with outerwears and have had no issues at all.
I plan on doing some tuning this weekend. I will see if there is that big of difference with them removed.take em off and enjoy the unrestricted power!
Outerwears work fine for a race ski. You do have to adjust your carbs a bit due to restricted air flow. For what most of use are doing, they are not gonna work, race ski's do not dive underwater and suck in gallons of water.
