- Cape May Court House, NJ
Why do the predator foot holds have such small mounting hardware ? Is that why you run a dakine strap @tightithrash?
They don't look like they would hold up to much abuse
can't speak for the foam or for the design of the holds, I can say that the hardware is not a weak point. I stuffed my nose into the sand very hard 2 weeks ago, i actually pulled the little square peice that sits down in the track through the track because i had the rear square set right at the cutout in the center where you would insert the square. I reistalled the square and moved the holds back a 1/2 inch and no problems yet
