- Sacramento
Agreed. You mentioned fuel issue and I had the same feeling.Damn, I was close! Sounded like a fuel delivery issue . . . double check your one way to make sure its working correctly also.
Definitely going to check fuel tank now that I noticed debris in in-line filter. Next step is carb pump because I have a feeling there is going to be some type of debris in there.From your description it sounds like an exhaust leak or fuel delivery problem. You usually have spark or you don't. A bad cdi or stator may lose spark then regain it, but normally after it has cooled down. Not immediately.
Have you pulled the hood when it quits to look for smoke?
Check the internal filters on the pump side of your carbs, in line filter, and check tank for debris.
