Is there no insert for the tank hook? It looks like your missing one between the 4 battery inserts and the single insert across from them
Yup he is. Same exact thing happened to mark OlsonIs there no insert for the tank hook? It looks like your missing one between the 4 battery inserts and the single insert across from them
Cutting them could be dangerous. It could take on a lot of water if flipped upside down. You and mark should talk to Derrick about this issueAnd my breather tubes are in the same spot. So I'll have to cut them to run a b pipe.
That sucks having your parts stolen, shoot me your address and I will send you a set of porting templates, save you a couple bucks at least.Well a few updates some good and some bad.... first the bad news.
I had a box stolen off my front porch last saturday that contained about $550 worth of goods from Jetmaniac.... so im currently dealing with that and trying to recover some of my lost items and or money... but i have zero faith...
Recevied my RRP Lite pole, this this is spectacular and cant wait to play with it some more! Had to toss on the Thrust EZ Mini steering and my RRP Freeride bars for a quick test and its soooo smooth!
Also got my new/rebuilt RN midshaft for the build along with my Free ride innovations throttle lever and a couple other accessories.
Not sure what im going to do about the motor at this point, but im thinking of porting the top end myself and then tossing in a new crank with some pro x pistons and then saving up for a stroker setup from holeshot and doing a bad ass 62t cases with a 760 top end all ported out professionally. but thats on the back burner as I try to recover some money first.
Cut that pole down pronto. Sucks to hear about the stolen stuff
