I have the knowledge of working on jet skis professionally since 1985 , I will leave it to you to figure it out from there. The pulse does not care if the fitting is straight or curved, soft pulse lines or overly long pulse lines will dampen the pulse past that it really doesn't matter, you want a pulse line going to each carb if the fuel pumps a carb mounted or a single pulse line if you are running an external pump, it's a pulse of mostly air with some fuel mixed in basically at a 14/1 ratio give or take.
