Just wondering what pump set-ups are being run on this size motor, Ill be running X-Sceam 771 next year, I have a 9/15 Hooker but Im thinking with the increase in power there should be a better option
I have a 85.5mm bore lamey pv motor Stock stroke. I have been through a number of set ups including a hooker impeller and 140mm mag. Best all around set up I had was a tbm cone and 13/17 skat or 13/18. Currently have a hooker impeller and tbm but am going back to a skat 13/17. The hooker just kills my mid range power. Feels like my motor is stuck in low gear. The 13/17 gave me clean power throughout the rpm range. The hooker is nice for hook up, but my motor just prefers the skat
I had the 9/15 Hooker on my ported 760 and felt the same as you describe. I replaced it with a 10/16 and the ski came alive. Trying a 140mm Mag now with a 14/19...
Are you getting your mag from Brian?
Hi. I have a LPW 771 and I tried a 9/15 Hooker and just didn't feel like it was right. Now I am running a 13/17 Solas with a 3mm cut back and much better. I also have my nozzle bored to 86 and WetWolf freestyle cone. I would agree with above comment about it lost mid range. In the spring I will be trying a 140 set back Mag pump.
Moto360
Moto360
A stock 13-17 Concord is a lot of load. Just bend the trailing edge up and it will come alive.
I had a 10/16 hooker on my LPW 771 and it was perfect. I have a 14/16 -3mm cutback solas concord that would probably work well for that setup too. $110 shipped
Pitch options are:
9/15 (for anything from a stock 701 to a strong limited set up)
10/16 (for the more healthy version of a limited with porting, big carbs, etc)
11/17 (for maximum hook up and added HP)
