Freestyle Pump tunnel of a 155 pump on these flipping skis
piratelife
Frandsen works
In the hood wood
Are you sure about the rok r matt? I know jeff (WDK) has one in his. But I'm not sure if it just "bolted right in". I know the op is just talking about pump tunnel. Dose a 155 mm just "bolt in a chan"? Not meaning to thread jack
Off Site
Matt's photos of his tunnel are really good, I was wondering if I could build up around the pump shoe. It almost looks like a sxr bottom, with a ride plate similar to a Backie Chan. I'll have to figure out the ride plate configuration too. Thanks for the link, Matt.
air blair
you are the reason
revolver
krash
Sent from my SPH-D710 using Tapatalk
yeah I am sure about the ROK-R.
The bolt pattern for 144 and 155 pumps is the same. But the diameter of the pump body is obviously different. This is what bolt-in vs non-bolt-in comes down to. Also, the pump shoe for the 155 is a bit larger.
There is probably more to making a 155 and larger work than just making the pump shoe fit. The intake tunnel must feed the larger pump, too.
burton391
in your house
WA
But are you sure sure?
piratelife
Frandsen works
In the hood wood
I know the bolt pattern is the same matt. But what im asking is what other modifications have to be done if any? Besides the pump shoe. Dose the hull need to be grinded? Dose the plate have to be changed?
You had the ride plate on too? Good to know it bolted right up and everything lined up no worries. I wonder what Jeff's issue was, you guys should've out it in I guess :shrug:
