- Charlotte, NC
which carb cleaner did yall use to soak the carbs in??.. i have a set that are kinda crusty in the jet area..
Only in California....read the back of that can bro it says its know to cause cancer to the state of california, i wouldn't try to "take the burn" you dont want that stuff on you AT ALL
Ill take pics of next carb before and after tomorrow when I get gloves. I use acetone and all kinds of stuff and can usually take the burn but this stuff was pretty intense.
ZERO, how far do you disassemble them before soaking? I ask because your before picture has the set screw in. Will the soak damage the orings or throttle shaft bushings?
That stuff also works awesome or decals and old turf glue![]()
