Yeah. Had to get a midshaft spacer. Got it in midweek. Got midshaft installed. Motor set in and shimmed. Started working on waterlines. Got to do it a bit differently from last build. Plus it is harder to get to up under there. I did get poke install completed. Had slight issue with pole bracket mounting holes being drilled out of square. Had to pull pole 3 times to try and get it straighter. Swapped to Thrust OVP. Smooth as butter.
All good stuff. Do all of these need a midshaft spacer or should it work with 96+ SJ midshaft? Do you want to sell your Pump alignment tool?
