- Oceanside, CA
Nice!
Are the mounting plates grooved on the bottom or something? I'd look but am out of town.......
No, you can set your spacing. Leave some room between your couplers, you don't want them touching. When your doing your engine alignment make sure to do it without your coupler in.
You can see my MM where the bolt is facing up with a nut at the top. I just did a nut, washer (ontop of MM) then nylon lock nut.
Fr2 labeled fs2 is what the man said! Sweeeeet
