Not sure what I'm gonna do yet. How does it change the handling with the rear tank? Is it better?
Haha, I have not even used it yet. I have fuel line blocking off the pick ups so water doesn't get it there. At least by not using it, later when I do, I will have something to compare to. Right now there is no point in running it cause i'd have two extra gallons in my ski for no reason. Just more of a PITA to load/upload with extra fuel in there. The reason I put it in there was because at some point, like yourself I plan to upgrade to a larger engine. When I do, I want to be able to ride as long as the guys that are running the 701 or something similar. In oceanside, when your out of gas, your go back to the harbor and your done not just pull up to the beach and refill.
Installing that rear tank is something your going to want to do right from the get go, otherwise your going to have all sorts of holes on your bulkhead from your ebox and what not. I was really torn between doing it or not, and I decided to. Im glad I did.
Dude I was 110% joking that's why I gave you the winkey eye
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I don't run 38s on any Ported motor. On a 950 I'd run 48s or 49s
Didn't see the wink, I usually try to look over winks from men and pretend like they didn't happen. Sorry. Even 46's should do. Dasa has some new carbs, you should try em sucker.s
