Sorry I haven’t given an update in a while. It’s first trip out I sank the ski because my cooling line fell off and filled the hull with water. Since then I rebuilt my motor from the ground up. New oem crank, pistons, seals and gaskets.
I’ve taken it out a few times to test and tune however I’m still having a problem with the B pipe coupler from the elbow to the expansion chamber. It keeps slipping off. It’s very annoying I’ve had to fix it about 6 times. I’ve ground down my engine mounting plate so it doesn’t touch the pipe and the chamber doesn’t contact the hull. The only thing I can think of is the hose from the chamber to the water box. I think the pipe is to low in the front of the ski which causes the coupler in the back to slip off the top side of the elbow. Has anyone experienced this?
Other than this everything is great and I love the ski!
