RICKTER talk
tomski
X
LHC
I have the PD1900 (on left) new in stock. $110 plus shipping.
The instructions say to keep the original flap on the Rickter scupper.
I replaced my 4 year old rubber flap on my FS2 last year as it had a little dry rot. Never did take on water but I also never floated in the middle of the river or lake for hours.
If I ever was just floating and taking a break I'd check it with my hand to make sure it was still there or closed.
I think its important the rubber isnt all dried out and flimsy in order for them to work properly. I don't have any surf for thousands of miles otherwise I'd robabsky of relaced it by now.
Either way both options do the same with 1 having more bling factor that requires more work(I want one)
Tuscaloosa, AL
What have you all done when running an OEM Tank in their Rickter to help keep the tank from shifting or twisting? I have the OEM Rubber stop to keep the tank from sliding back. I had a sheet of 9mm under pad up under the tank. The tank does not really sit in a cradle like the tank does on a SJ. Was looking at installing some 20mm foam blocks on the sides to kinda help wedge it. Just curious how others have done this.
Stockton
^^^^^ I use Eva block, about 2 inches tall so tank can't slide up on top of it, 20mm is thin. Also have bottom of tank turfed but I removed a couple 1 inch square sections and glued those to hull, so they lock together like a puzzle..
MarkWalker
Buffalo NY
What have you all done when running an OEM Tank in their Rickter to help keep the tank from shifting or twisting? I have the OEM Rubber stop to keep the tank from sliding back. I had a sheet of 9mm under pad up under the tank. The tank does not really sit in a cradle like the tank does on a SJ. Was looking at installing some 20mm foam blocks on the sides to kinda help wedge it. Just curious how others have done this.[/QUhttps://
This is what I used. In stock at Wal-Mart. https://www.walmart.com/ip/ProSourc...gh-Density-EVA-Yoga-Bricks-4-x-6-x-9/49967545
Oem sj tank rubber block with a sheet of turf under tank works perfect on my XFR. 5200 it down, never budges. It’s about a 3/4 inch from the bpipe chamber and never gets closer. A knot in each strap helps. My tank is the cf oem style though. Not true oem
Stockton
Your thinking correctly, With your ride style you'll want the side blocks so it stays put. I.e. double barrel roll, barrel roll or accidental side landings..
6" x 6" industrial velcro working pretty well for me so far. They have some stuff that uses same epoxy/glue on gopro mounts and will not come off easily. Of course all bets are off if you have a lot of gas/oil sloshing around in your engine bay, but working well so far for me.
