RN Superflip Build
Little update..........Been ordering some parts and slowly making some progress. I got a Carter B Gen 3 Rocker, Front Foothold, and Tubbies. Also got Hurricane boxes and am going to buy RRP Ninja Footholds to put in the boxes. Now I'm starting to reinforce under the tray and am going to put the tray back together. Goal is to flip it off boat wakes.
I have the same set up and love it! I did a 2" taper off the side rail to take off the back lip. Don't think you'd want anymore of the side rail removed.
Reviving this thread and getting focused for the "off-season" with a new goal in mind. Trying to do backflips of boat wake in the Barnegat Bay in NJ. Stay Tuned
Parts Parts and More Parts
Doing a custom rockered rear. Looks killer and very functional. Lots of work left.
More progress. Hard only being able to work on it Saturday and Sunday. Will be reinforcing the inside with 4 layers of 1208 next weekend then making custom tray.
More from this past weekend. Mocked up the pipe to see fitment and it should work with minor altering. Also reinforced the inside with 4 layers of 1208 on the inside.
Starting to look more like a ski again. Well sort of.
Found out why she was still a bit heavy. Someone decided to go a bit crazy with peanut butter and also did not prep. On the other hand, Carter B's rocker nose looks good already! that was just a rough fit as i need to trim etc.
I'm about to start taking apart my 9` SN hull, will probably end up following what your doing in this setup along with all the other SN hull mod threads. Awesome pictures showing each step, These will help a lot since this will be my first time working with fiberglass. Keep it coming dude.
Thanks man. All i can say is take your time and do it right the first time. If you have any questions, pm me or just ask. It is my first time working will glass also.
