- Amherst NH
If I can put my lips to the plug and blow air into the hull then that means the plug is leaking. I then replaced them with versiplugs and no more leaking.
Its not the sealing against the hull , its the hole the ball seals against can get distortedIf I have learned anything from this thread, I . going to need to put some silicone or 5200 on my 701 surf plugs before installing them.
You can see by the pic of WB 1998 he has his feet on the ramp. When you shorten your ski, your whole body position has to change. I have seen a lot of people keep their feet in the same spot and ride like that. Foot straps need to go about 3-4 inches forward.
Also, this skis are for riding inverted, and getting deep into the wave. If you just ride fast and do the odd jump, its may not be for you..
once you rocker the front kiss any speed goodbye.
