701 Kit works about 70% as well as a Rocker Nose kit
Blaster Kits -
there are 4 moulds i believe, 5 nose types..
Zipties nose kit, super steep nose, very short. (friday's in W.A. has kit)- hardcore turning, short as, which is awesome, a poop load of water in your face - splash guard will fix that. - Skis that have similar or same. (matt's new blaster, fibbo's blaster, keirens Blaster) - Loses gas cap, not good at top speed.
Player 1 Blaster Nose. Gradual Rocker, Small chines - (no production copies available). no spray, a lot looser and slides more than above and a bit longer, ski still goes flat out no problem.. keeps gas gap. rotates smooth as there is little impact resistance.
Carter B new nose (my nose, upgraded to try and get the best of both worlds, is available). - Longer, turns quite hard, a bit of splash, no splash guard. Has more aggressive chines up the sides so grips well.. keeps gas cap - however you could bond it closer to make it shorter.
(Luke Rotoloniewithcheese has it, I have it on other b1, and i think a few others, about 8 skis or so, now ever more in the states.)
Jay's new nose / Super steep still - ( no moulds yet) - hardcore turning (like 1st nose), shortish, no spray, has splash guard. I'd say this is Gen 2 of "zipties nose". definitely a bit better. - Loses gas cap
Carter B V2 of above - adds splash Guard.
Personally i like my longer nose, but i also love the shorter nose and the hardcore turning of jays nose. it's like having 2 surfboards, one fun board and one comp board. The less agressive noses go through the lip better, the more agressive harder. the bigger the surf, the less agro you want the nose. The nose is meant to compliment the curve of the wave. With every wave different. that should be easy as.
The rear end. The shorter, the faster it rotates.
It makes regular trick quite hard. But as see here with Pierre (2min mark). You just start doing everything inverted. Thats the Player1 Blaster nose and the rear chopped to just before the the pump tunnel bolts
People are now cutting shorter than the pump tunnel bolts , but letting the tunnel hang out like a jet boat. that will be interesting. Or just buy a reaper, somewhere completely new and different.
