Rockered shortened Superjet build
Pablo
sqeez bth levrs & lean bk
georgia
Shouldn't b doing the 5-finger shuffle while u got a saw in ur other hand. Gives a new take on "the stranger" if u cut ur finger off. ;)
Hella nice build though.
KTM434
Jamie FN Hickey
Palm Coast FL
Haven't updated in a long time but tray took a lot of time to shape wider and add custom footholds but it was well worth the added labor. Only thing left from the original holds are the black tips haha
KTM434
Jamie FN Hickey
Palm Coast FL
Decided even though carbon/Kevlar is cool... It just looked outdated. It's still down there but covered with bright white paint.
Ski looks much better all white IMO.
Before and after at this point:
KTM434
Jamie FN Hickey
Palm Coast FL
Pump installation:
Midshaft, couch mounts, pole bracket ,exhaust tube:
Holes drilled for bow eye (nose was Layed up to handle abuse):
Made sure to find a pole spring that would work with this setup. I hate tight poles and not having a spring can cause back issues... Ask me how I know:
Versiplug max for proper drainage but good leak protection (not a fan of scuppers):
Buttery smooth steering system and 50mm riser bars and quick steer mod at nozzle:
Made battery cables that'll handle abuse:
Pole pad that won't fall off and doesn't require contact cement on hood:
New carbon chinpad for the Xmetal pole:
Cut the rideplate flush with the hull which left a lot of scrap metal:
