- South Florida
That seems heavy for such a tiny hull. It must be heavy duty as all get out.
Jeff builds these hulls with a pretty solid/thick layup. I've only gotten to poke around at the full carbon ROK-R, but there is no flex anywhere.
And while it may be short, it's also pretty much SXR size except for the length. That's what makes the tray look so funky. The hood is full size SXR.
What does carbon hull weigh?
Yeah I figured I might just start making hulls myself. Pretty easy seems like every monkey is making hulls now.
Mine will be 11 lbs, you can drop it out of the sky with zero damage. It will double as a Diamond tip drill bit for drilling oil wells.
This hull will change the world of freeriding. You can also get the larger prop mods to make it an airplane so you can fly to freerides.
It will not be a copy of any other hull and it will Always give you a happy ending.
As for the Rok-r it seems the real important part is the long rideplate.
post 38 chrisWhat does carbon hull weigh?
Watching these threads unfold is hilarious. Everyone seems to be an expert on what everyone else was thinking or why they did something the way they did.
Everyone is an expert about everyone elses stuff. Ride a new hull once and now you are a hull builder. Tip a couple of strippers now you are a big Player.
^Someone has the winter blues^
