- HUNTINGTON BEACH CA
so i bought the light weight pole, because it looks way cooler. bad call. first issue i had was that the lower portion was too flimsey w/o a spacer in place and it was too hard on the back with the spacer in, instead of a spring. i fabd up a spacer out of some Ti that i am able to use both a spacer AND run a spring. problem solved.
next issue is every time im done riding i inspect it to make sure all the harware is still tight and pole is still solid. i noticed that the left hand tube (looking from the tray) always slides up about a 1/4" some times even 3/4". the first time i thought it was because i torqed the pinch bolts improper, so i re-torqed them to spec and still had the same issue. the last 2 times i slid the pole back down i torqed them down REAL tight and still have had the same results?
anyone else have this problem? im running the 26" tubes.
