Check the Ignition Coil Wires.
Maybe broken near the Plug Boots. Can trim back Wires a bit and install new Crimp Terminals.
Perform a Primary and Secondary Resistance test on the Ignition Coils. Small Wires (Orange and Black) should read close to Zero Ohms. Secondary (Plug Wires) should read around 3500 to 4700 Ohms steady. Flex the Plug Wires along their length to see if readings change. A change would indicate a wire break.
Or can just swap in a Known Good Ignition Coil.
Would also try a different Battery. Make sure the Battery Negative Cable is clean and tight since it's the Ground Wire to the Battery for the Engine.
I can test them but I'm almost certain it isn't coil since I already changed that out for a OCD rebuilt w/ new wires, plugs etc. from JM. Battery is relatively new and ground is tight, I ground to stator bolt so I know it's good.
