The screws on myb pipe are all broken off, is there any way of salvaging it? Unfortunately, it looks like someone has tried to repair before, so to find the center of the screw and re-tap might be difficult too, one hole is worse than the other two.
What exactly do these screws do inside the casting? Does just the screw diameter interrupt water flow, or are they turning some sort of butterfly valve or something inside? What if I put a significantly larger screw in?
Also, I ripped a wire off of my stator, I am going to try to re-solder it, is there a way to tell if it is making connection/stator is good? I know on lawn mower engines you can test the resistance through the stator (ohms), is there a procedure for this on ski engines?
Thanks.
Thanks.
