- Outer Banks, NC
Brian asked me to post this up for him.... Can't wait to see some longer videos! Hopefully, I can get this right!
works fine for me!
I like the wisdom tooth removal video better. Bastards wouldn't let me keep my teeth either. Those doctors must hawk them for crack or something...
how will the bigger stroke cases handle a smaller crank in regards to case volume
So if you want a stroker crank to fit, I would assume it has to be sent back to be machined again....
Posted via Mobile Device
Its not my first day ethier
I was talking about the case volume in the crank throw area
clearly the crank pin needs clearance to go around
I was just wondering how much more had come out and how do you think a smaller throw crank would run with the increased volume
I can understand if you had to send them back for bigger stroke cranks but you said that the 10-12mm will accept the std stroke cranks so i assumed that they were already clearanced for the bigger crank from the factory
