- detroit MI
anyone ever separate the top and bottom ecks on an x2? how much does it suck? i'm not too picky about the pump tunnel/uner seat area as the new one will be flat decked.
You should cut it as close to the outside as possible leaving as much as you can of the bulkheadlooking through your thread thats what im thinking. because i may nee parts of the top bond rail.
the bulk head im still having trouble with. because idk how it will mate up with the new bottom deck depending on how i cut it. should be interesting. will pm u as i get going on this vumad.
ultimate goal of this project. superman seat grab. and other tricks i miss from my motocross days.
okay so leave bulk head attached to top deck as much as possible. will do.
I'm curious to have a better idea of what you are doing. I have a hunch you are going to make this way more complicated than necessary and end up with some serious alignment issues.
well considering my jeep went from a simple axle swap to a full blown conversion changing every piece other than the shell and seats...... yeah thats a good assumption rofl. im not using an x2 bottom deck. that is where in the issue lies. i want to try something vastly ifferent and actually run a totally different bottom deck with native yami mounts and pump tunnel. i love riding my x2 but jumping it is not what i expected. i want it to jump like some of the aftermarket hulls i rode this weekend. so it needs to be lighter, shorter, and have a vastly different bottom en construction. i originally contemplating polishing the terd and filling it like most do but i like to make life complicated
Im going about this same thing myself , just in a different way. The first thing you need to do is take your bottom deck and put a drivetrain in it then set the topdeck on it. Thats everything including pipe and carbs. The X2 uses the longest driveshaft that kawi made. To get it to work your going to find that you need to manipulate the topdeck in more ways than just chopping the back end short because of the shorter driveshaft.
just looked through them real quick.... all that and he still hasn't flippe it??? well this is looking like a good idea at all then.Have you read the threads on PWCtoday by phlipcyde?
http://www.pwctoday.com/showthread.php?t=356987&highlight=
http://www.pwctoday.com/showthread.php?t=345769&highlight=
http://www.pwctoday.com/showthread.php?t=247779&highlight=
no i havent read those. i will have to o that when i get some time this weekend.
that is pretty much the plan. to first actually split it then see where it all sits. just hoping it all lines up. the bottom deck won't be using a single kawi part. it will be all yami.
