All stock I'd agree. With pipe I'd lean to the 46. Overbore or porting with that pipe and I'd be all about the 46 personally.44 would be better
I believe this post to be accurate as I have ran a 61x with a 44 wide open and never had a problem. My question is Why do you think a larger carb is more prone to stick a piston? I run a single 48 tuned with a 2.5ns although I do not run wot for very long in the surf. I was just curious as I swap motors between my Freak and Proforce and was wondering how the larger single carb motor would work in the Proforce with a V3 laydown pipe. I have stuck several pistons always the rear cylinder using dual carbs and now run a larger main jet in the back carb. The only motor that was reliable in the proforce was the little 61x with a 44 it was kinda tired and slow but it ran and ran and ran and had almost a 3hr range without refueling. Anyway looking for thoughts and ideas about putting a larger 62t/singe carb motor in, as I wont try it if its gonna seize.A single 46 or larger is fine for throttle blipping, they tend to go lean and stick pistons on full throttle runs. A 44 on 61x cases tunes well and is safe for holding full throttle. For better response and ease of tuning get a pair of standard SBN44s for your 62t Case. Its the best combo that I have found for anything that's not going to do a flip.
Thanks I`m going to stick with the single carb for the surf and only use the 61x in the proforce as a backup or for endurance rides. Still scratching my head wondering why if it works in a 61x why not a single on a 62t? My jetting for my 48 is 140m 125l 2.5ns 95gr 1turn out both, I never checked popoff but it runs great seems to run wot with no issues are these settings similar to yours? When I go to a 145m it was not as crisp so went back to the 140m and its not broke yet. Tuning is something I need to improve on lol so i appreciate and enjoy reading opinions, thanksThe full throttle lean out is something I figured out the hard way. I could install a big main and open up the top screw enough to sustain full throttle. By then it would stumble on spool up. If I cleaned up the main it would get too lean at full throttle, I could hear the detonation buzz a couple seconds before it stuck. This was confirmed by others on the sight many years ago. Just be aware of this when tuning the main circuit. Make sure it will hold a rich setting before you lean to peak. A pair of 44s wont do this and still tune easily on smaller engines. A pair of 46s by comparison need a richer pilot/popoff setting and are more sensitive on small engines.
