waxhead said:i have sey up a songle 46 on a ski that had the same portjob and pipe as my ski
i had twin 44
they had a single 46
Mine would kick its ass for low end reponse and power
both skis were ported 701 with b-pipes and msd
milled heads,
both were surf skis
the really bad thing about the single was it would go flat up top straight away
so you would go for a wave gas it and it would pull though not well and then it would taper off up top
Takeastand SJ said:I recently switched from dual 44's to a single 48 powerbomb and couldn't be happier. People that say you can't run them wide open don't know what they are talking about, ya you can't go run wide open for a half an hour but it is more than enough for the surf. Setting the carb up right gives your motor more than enough gas, external fuel pump, right size return line restrictor, etc is all it takes.
orange flattop freestyler said:This is aways an interesting read but for the record,
i run twin 48mm Riva power bombs on my freestyle boat and they hit harder than any other carbs ive ridden on,
bigkahuna said:Hmmmm let's see..... TLR started the single craze with Rick Roy's setups.......... He did my porting............ stated that with his porting (or any porting) that he recommended a single setup (using his modified carb) that the throttle response would be incredible, but Do Not Run WOT with this setup or any single carb, that it could not safely provide enough fuel at higher RPM's......( Understand, this is with using 62T Cases), the motor would lean out..............
Takeastand SJ said:So the 100 times I have ran my motor (62T)wot for 10, 20 seconds at a time has hurt it somehow? Sickerlings 900 with a single 46mm carb doesn't work? Taylor Curtis won O-side never running his motor wot? I'm not going to argue with you, if a single carb is set up right you can run it wot for short periods of time with no problems.
Takeastand SJ said:Good example of a single carb not tuned correctly.
WaveDemon said:I don't know how an undersized carb can lean out a motor. The throat of the carb will only allow so much air to pass through. It would have to be a poorly designed carb to not allow enough fuel to match airflow at 14.7:1 ±
