SX/SXi/SXi Pro sj pump to sx hull
D-Roc
I forgot!
I would probably just shorten the back of the 550 to make the pump set back. I believe the water into the prop benefits having the shortest distance, not a longer distance. That's just my opinion.
Great work on the ski. Having a big pump is what every Kawasaki needs, and you did it. Very cool.
im out again this weekend, should give me a better idea of what this thing is like, first outing was only a short shakedown session, it was bloody freezing !!!
well its been a while so i thought i would share the latest mods to the ski. the biggest one is the titan pole, this is BY FAR the best mod to the ski, it has transformed the way it rides, increases your confidence no end knowing its not gonna snap at the first nose stab attempt, awesome just awesome. add this to a loki customs full port job and hey, worlds your oyster ! pick up on the motor now rivals an sj easily, the lad john is world class at this sort of thing and his past record proves this. still got a few plans in the pipe line so stay tuned !!
Such a sick kawi . Do you think it's a back flip capable ski after all the mods ?just wondering because I want to do my kawi similar to this ?
yes its deffo a back flip hull, surf only tho, I will be modding the intake area in the next few weeks, at the moment it comes out the water waaaayyyyyyyto early, and thanks for the kind comments
as the boys I ski with are all off the water for various reasons, thought I would do some long standing mods, , the ski was getting a little heavy at the back end, and after drilling a hole to see if any water was in the tray, i was a little surprised to find over a gallon come flooding out !! so tray out, then removed about 25 lbs of crap from the tray area alone !! then a little think on what else to do, set the pump back 3", so out with the grinder and pump tunnel drops out. then its a good clean up and remove all the glue and sealant from inside the tray, so much of it, no wonder these things way a ton !! its all lined up and glassed in plus re enforcing the tray side ready for the rickter ninja type footholds im making, still a bit to do, will add pics as I go
all done with the glassing on the bottom deck, with a single layer of woven roving over the top, all ready and sanded up for the gel coat, pump and ride plate should be on over the weekend
this is how it used to ride, but should be a damn sight better with the new pump set up, im getting a solas 12v in the next few weeks, as you look at the pic you can see how far forward the old set up was
here we go then, nearly ready for the final push, tray and sides all foamed up, cut outs for the new footholds in and all the bottom deck gel coated and polished
nearly all done now, footholds are AWESOME !! feel a load better, locked in and comfy all at the same time, who knew !!!, bit of turfing to do on the holds then im off for a solas pump instal tomorrow from Loki customs, with the set back tunnel, the new pump/footholds and the weight shedding im expecting a big change in the way it rides...........we shall see
