Bobert540
- Rockford,MI
Is it worth changing out the stator as well?
So I was able to change the stator out. Still have the same issue after about 20 minutes of riding. Brought it in checked plugs front cylinder looked a little lean rear almost looked fouled. Started the ski up the next morning ran fine for the 5 minutes I rode it. So I don't think it was a fouled plug.
Could this be a symptom of a bad CDI?
Having the SAME exact issue with my 96 SJ...It's drivingme nuts. I replaced the CDI, no luck. Any luck with yours?
the offset plug colors sounds like crank seal issue.
