Ski runs great for 10min. then bogs...
Bobert540
Rockford,MI
Cooling issue fixed, exhaust leaks fixed. Ski runs great for about 20mins or so then it bogs again. Plugs looked a bit on the rich side, one even looked fouled. So I changed the plugs ran good for about 1-2minutes then bogged again. I am going to change the Stator this week. Any other suggestions? Thanks!
Bobert540
Rockford,MI
So I was able to change the stator out. Still have the same issue after about 20 minutes of riding. Brought it in checked plugs front cylinder looked a little lean rear almost looked fouled. Started the ski up the next morning ran fine for the 5 minutes I rode it. So I don't think it was a fouled plug.
Could this be a symptom of a bad CDI?
jerzey
Squares For Life
South Carolina
Could be Bobert.....almost sounds like the same problem Kevo's having. I have an 09 sj cdi and a few 6m6's on the shelf that i offered him to see if thats the problem...you are welcome to try them too.
munki63
Epoxy is my duct tape
Canada
Having the SAME exact issue with my 96 SJ...It's drivingme nuts. I replaced the CDI, no luck. Any luck with yours?
Go for a ride with your hood off, it's the easiest way to check for an exaust leak, in the past when ever I've had a bog after a few min it's always been exhaust, so both of you go for a rip with you hood off, if the problem goes away you found it
New York
Tried pulling the cover today seemed to help for a little but issue came back. I opened the ebox and switched out the coil. The old one looked like it wasn't grounded well and the plug wire resistance wasn't reading well. I didn't get back out on the water but it did sound much better on the trailer. I will update how she runs when I take her out on thurs. Bob def check the the resistance on your plug wires the specs are in the service manual and yes I have read where a bad CDI causes this that is why I started there.
