in the process of building this thing... probably licoriceing all kinds of poop up in the process. Well, sold/traded my dirtbike, sumo wheels and a ton of other crap and picked up a DASA 850 pv motor with blackjack carbs, RR pole and steering, 144 setback mag pump w/ Thrust trim yada yada... waiting on a pump shoe to get to the next level w/ powertrain. Thanks a ton to Tem for the bomber of a hull. this thing is a fortress at 95lbs (hull, hood, holds, ride plate). It was built heavy cause I do not want or need a light hull, so don't judge his based upon weight. I know how you licoriceers are about weight... I bonded the hull last weekend so all the fun stuff is ahead...
