- NH
Ok so I started this build back in early March and got in way to far. I was just going to do some reinforcing on the hull and then bolt on some a/m parts and put a decent motor in.
Here is what I ended up doing:
HULL
Cut hood
Reinforced hood and took out liner
Reshaped nose
Defoam and refoam with X2 under hood foam
Reshaped tray
Cut 2'' off
Glassed in tubbie 2's
Returfed rails and tray
Foothold unknown(wish i switched them)
Reinforced engine compartment, nose and tray.
Snap Strap Hood Straps
Jetmaniac pole limiting rope
Two 500 GPH Rule bilges with OCD solutions harness and switch
Drain plugs
STEERING
RRP pole and bracket
Blowsion carbon pad in white
Cold fusion steering
RRP riser bars
ODI grips
CATS trim
MOTOR + PUMP
735 62t/61x jetmaniac motor
BlackJack 38's
Factory Pipe limited chamber
Rad Dudes exhaust tube
Protec CDI and JSS coil
ADA Girlded head 35cc domes
Filled intake crossover on stock intake
Jetworks FCV
Jetworks carbon reeds
Jetworks hooker A prop
Stock ride plate
Worx 201 intake grate
This is my first ski build and I am proud to say I did everything on my own. Because of this though the fit and finish isnt as good as I hoped but I learned alot and had fun. I got alot of stuff powder coated to give it a final touch and Im going to be doing some graphics to make it look kinda like a fs-2 hence the SNICKTER name. I know the name may be ghey to some of you but it just fit ya know.
I would like to thank Art from Jetworks and Chris(Jetmaniac). Both of these guys took alot of time to help answer questions and get me parts.
HULL
Cut hood
Reshaped nose
Reshaped tray
Cut 2'' off
Drain plugs
STEERING
RRP riser bars
ODI grips
CATS trim
MOTOR + PUMP
BlackJack 38's
Jetworks FCV
Stock ride plate
