I need one of these......When you say the complete Pump - Does it include the reduction nozzle and steering nozzle?
Pumps are custom built and include whichever parts you need.
Got mine installed, made a big difference on a heavy a** superjet. Should make a huge improvement on a A/M hull. Thx again Chris
I heard about at least one person with a freak where the shaft was too long. Will I need a custom length drive shaft?
Chris
Are all of your shafts the custom length or is it special request?
how much for the solas 144mm 12 vane ss mag pump for my 97 superjet with a big hub impeller which i have to get right?
They fit in oem hulls with the oem SJ driveshaft w/o issue.I was wondering if I need to get a different driveshaft. I am goin to be putting this pump into a 92 square nose with a gp1200
what about 148s?
Solas 144mm 12Vane nonsetback SS MAG pump for Yamaha 469.
View attachment 176472 View attachment 176471
These are the new all stainless steel 12 Vane lower cost 'MAG' pumps that many have been talking about, JM earlier review here:
http://www.x-h2o.com/index.php?threads/solas-ss-mag-nonsetback-144mm-pump-review.103667/
These pumps replace your stock pump vane section. They are non-setback so they use your same stock driveshaft and will fit directly into your superjet -SN or RN including '08-'12, or Waveblaster.
You use the same wear ring and reduction nozzle from your oem pump.
These are big hub pumps so you do need a big hub impeller made by skat-trak, impros hooker, or solas.
Medium pump cone and SS allen hardware included
Oring for reduction nozzle and impeller washer/spacer included
*OEM bearing and seal kit 89.90 discount to 76.
*Freestyle short pump cone for the Solas pump 55.
JetManiac is also offering Solas pump builds with bearings, seals, driveshaft greased and installed -ready to install
Oring for reduction nozzle impeller washer/spacer included
OEM pump bearing and seal kit 89.90 discount to 76.
Driveshaft for SJ, '08-'12 SJ, or WB1 with clean oem splines 169.
Installation/pump build 85.
Total Solas MAG pump 799.
+add Impros hooker impeller installed option available
They do now!Solas doesnt make a 148, but we have skat billet 148s in stock.
