Spark plugs in watercraft
tntsuperjet
Tntperformance-engineering.com
Georgetown ca
I got a few PM regarding this so I will try to explain.
The BR8ES or the ES LINE of sparks plugs is designed for air cooled generators and motorcycles.
These plugs are not designed for high comp water cooled applications.
They require a lot of spark energy to fire at high rpm's as they where designed for low rpm engine.
There basically a generic plug.
Now watercraft industry has saturated itself with this line of plugs 6-7-8- and very few running 9 heat range.
The Es fouls quickly and easy in water cooled head because of its thin perimeter design and inset electrode.
Now you all running decent size bores 83mm or bigger, have weak plug in a engine that taxes the stock ignition do to higher Cyl pressures then stock. Yes more compression means more spark energy needed to bridge the plug gap.
So you need a spark plug that will help keep build up from fouling, proper heat range for your gas and compression, proper gap for your ignition and compression ratio.
Stock ignition coil is only capable of firing a .0010 or ten thousands gap at 8000 rpm at 200psi compression. The internals of the ignition coil and stator could begin to break down if the spark plug gap requires more spark energy to gap then to arc jump internally.
To give a better perspective a 3/4 in spark gap at 5,000 ft elevation takes 18k volts to bridge the gap. At sea level that same gap requires 20k volts. At 150psi pressure it takes 60k volts ( Rough estimate)
So as your compression goes up you increase the density of air and higher density requires more spark energy to penetrate through open space.
So stock ignition on a 62t ignition running 200psi comp is only capable of .0010-.0012 plug gap.
Yes that's ten to twelve thousands of an inch.
Now you need a spark plug that has semi exposed electrode isolater to allow for burn off of heavy deposits, thick outer containment area to avoid flash heating.
How to find a spark plug that is best for your engine??
your engine builder should have a plug that was designed for your engine.
But if you at a loss for a plug try ngk BR9EYA.
That plug was designed for large bore water cooled two stroke.
Do not run it at over .0020 gap with stock ignition.
Rule of thumb
100 psi comp .0032 gap.
-.00011 gap for every 10psi over 100psi comp.
min gap is .0010-.0012
eastcoastjumper
James
Long Island
What about a bpr8es ?
bored&stroked
Urban redneck
AZ
If I reply only saying subbed, does this do something other then just saying subbed? Like internet powers or something?
yamanube
This Is The Way
Staff member
Mandalor
It does two things, notifies you of any new posts in the thread as they come up, and annoys the hell out of anybody who knows how to properly use the forum software.
If you want to be notified of further posts and not bury useful information further into a thread, use the "watch thread" link in the top right corner.
tntsuperjet
Georgetown ca
Bp is an extended tip Es will reduce fouling some but still requires same spark energy as ES
B8eg is none resister plug and will cause electrical noise that will cause timing I consistancy. With MSD product the b8eg will crash the ignition ability to process pulse signals properly.
cookn
Kamikaze
where you live
I thought non resistor plugs only effected digital ignitions? This is cool info. I have always ran b8es plugs with an enhancer. I have never fouled plugs but now I am curious if I could benefit from the suggested br9eya
scotts2t
Head Woop!
Lake Erie
What plugs do you recommend for a 190 psi ski with msd total loss? I've seen spark jump from my plug caps to head at least an inch. I've also noticed worse performance with iridium tip spark plugs than standard br8es plugs.
eastcoastjumper
James
Long Island
@tntsuperjet
What do you run in Brandon's Dasa ?
I have always used br8es plugs without issue in 81-89mm bore engines. Along with switching plugs, you are recommending the 9 over the 8 heat range?
I wish I were making it over to Grayland next weekend to talk with you, unfortunately I am busy and won't make it there this year.
tntsuperjet
Georgetown ca
Most iridium plugs are to noisy for get ski application.
If your seeing arcing from wires to head. You might wanna take your head off and clean the dome to shell contact. Your loosing your grounding of the spark plug.
Yami-Rider
TigerCraft FV-PRO
Texoma
How about spark plug boots, I've always ran ngk 5k resistor boots on stock ignition, not sure what that does to spark over the standard msd boots. I just like how they lock on and are easy to install.
